OS-V: 0533 Laminated Shell Strength Analysis Mechanical Load 3
This problem demonstrates when the loads applied in OS-V: 0532 are factored by 1.1491, a Hill failure index (FI) and a reserve factor (RF) of unity for ply 1 are obtained.
Examination of the FI and RF for each criterion confirm that only for the Hill criteria is the FI directly related to reserve factor, RF = 1/(FI)0.5. For all other plies, the RF are reduced by a factor of 1.149-1, but the FI is not. The model is subjected to a uniform longitudinal, transverse, shear, bending and torsional load per unit length. The geometry of the model and boundary conditions are described by Hopkins (2005). The resulting ply failure indices, reserve factor and midplane strains are compared against analytical solutions from classical lamination theory (CLT). 5 The results show good agreement between OptiStruct and CLT.
Benchmark Model
図 1. Composite Laminate Shell Subjected to Combined Loading
800 mesh elements of CQUAD4 element type were used in this study. The model is fixed at point A using a SPC card; a uniform longitudinal force per unit length (Nx) of 26.573 N/m, uniform transverse force per unit length (Ny) of 28.728 N/m and shear force per unit length (Nxy) of 5.7455 N/m are applied using a FORCE card. Bending moments per unit length (Mx = 0.45964 N and My = -0.8618 N) and torsional load per unit length (Txy = -0.20109 N) are applied along the edges of the laminate using a MOMENT card.
The material properties are:
Property
Value
Longitudinal Young’s Modulus, El (GPa)
207.0
Transverse Young’s Modulus, Et (GPa)
7.6
Longitudinal Shear Modulus, Glt (GPa)
5.0
Major Poisson’s ratio, υ 12
0.3
Longitudinal Tensile Strength, σ lt (MPa)
500.0
Longitudinal Compressive Strength, σ lc (MPa)
350.0
Transverse Tensile Strength, σ tt (MPa)
5.0
Transverse Compressive Strength, σ tc (MPa)
75.0
In-plane shear strength, τ lt (MPa)
35.0
表 1. Comparison of Failure Index for each Ply between OptiStruct (OS) and Classical Lamination Theory (CLT)
Ply Orientation (°) Thickness ( μ m)
1 90.0 0.05
2 -45.0 0.05
3 45.0 0.05
4 0.0 0.05
The geometry of the composite laminate:
Dimension
Value
Length (m)
0.2
Breadth (m)
0.1
Results
表 2 compares the average midplane strains computed from OptiStruct with CLT. The average midplane strains from CLT presented in 表 2 are of the homogenized composite; therefore, STRAIN I/O should be used, which, gives the midplane strains of individual plies. The identical results show that OptiStruct calculates the midplane strains accurately.
表 2. Comparison of Midplane Strains between OptiStruct (OS) and Classical Lamination Theory (CLT)
Midplane Strains Theory OptiStruct Result
ε x -1.9902 x 10-4 -1.990 x 10-4
ε y -6.3794 x 10-4 -6.4 x 10-4
ε xy -4.5136 x 10-4 -4.51 x 10-4
The ply failures show a good agreement between the finite element results and analytical solution with a maximum difference of 0.12% in ply 4, -0.005% in ply 4 and -0.02% in ply 2 when Tsai-Wu, Hill and Hoffman failure criteria are used, respectively. The values in 表 4 show that the RF are reduced by a factor of 1.149-1, but the FI is not. Therefore, the RF is more meaningful than the FI in assessing the strength of the ply.
表 3. Comparison of Failure Index in OptiStruct and CLT
Failure Criteria Ply 1 Ply 2 Ply 3 Ply 4
Theory OptiStruct Result Theory OptiStruct Result Theory OptiStruct Result Theory OptiStruct Result
Tsai-Wu -2.12900 -2.127 -2.76890 -2.77 -2.13250 -2.133 -1.13540 -1.134
Hill 1.00000 1.00000 0.29949 0.29950 0.08470 0.08470 0.64777 0.64780
Hoffman -2.56460 -2.56500 -2.51860 -2.51900 -1.99770 -1.99800 -1.36110 -1.36100
表 4. Comparison of Reserve Factor for each Ply between OptiStruct and CLT
Reserve Factor Ply 1 Ply 2 Ply 3 Ply 4
Tsai-Wu 1.6123 1.612 3.5651 3.568 6.3911 6.402 2.2331 2.232
Hill 0.99998 1.000 1.8273 1.827 3.436 3.436 1.2425 1.242
Hoffman 1.7718 1.772 2.983 2.983 4.9355 4.933 2.6439 2.644
This document addresses the verification of numerical results for the criteria and does not address the merits of a particular criteria. For details of particular failure criteria. 2 3 4
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /lssam3_tsai.fem
  • /lssam3_hill.fem
  • /lssam3_hoff.fem
1 Hopkins, P., 1986, Benchmarks for Membrane and Bending Analysis of Laminated Shells, Part 1, Stiffness Matrix and Thermal Characteristics, NAFEMS Publication
2 ESDU datasheet 83014, Failure Criteria for an Individual Layer of a Fibre Reinforced Composite Laminate under in-plane loading, 1986
3 ESA PSS-03-1101, 1986, Composite Design Handbook for Space Structure Application, Issue 1
4 A Comparison of the Predicted Capabilities of Current Failure Theories for Composite Laminate by P. D. Soden, M. J. Hinton and A. S. Kaddour, Composite Science and Technology, Volume 58, 1998, pages 1225-1254
5 Jones, R.M., 1975, Mechanics of Composites, McGraw Hill, New York
