Header Block
The header block contains metadata for use by file readers to identify the type, version and format of the file. This is a mandatory block. The keywords that are used in this block are:
Parameter Type Description
FILE_TYPE quoted_string The only legal value is 'gbs'.
FILE_VERSION quoted_string The only legal value is '1'.
FILE_FORMAT quoted_string The only legal value is 'ASCII'.
The following is an example of a HEADER block:
$-----------------------------------------------------------------HEADER
[HEADER]
FILE_TYPE     = 'gbs'
FILE_VERSION  = '1'
FILE_FORMAT   = 'ASCII'
