The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
The Altair Bushing Model is a library of sophisticated, frequency- and amplitude-dependent bushing models that you can use for
accurate vehicle dynamics, durability and NVH simulations. The Altair Bushing Model supports both rubber bushings and hydromounts.
This section provides information about using the Altair Bushing Model, also known as AutoBushFD, with MotionView. The Altair Bushing Model is a sophisticated model that you can use to simulate the behavior of bushings in vehicle
The Model Identification Tool (MotionView) is a utility in HyperGraph that you use to fit experimental data to various bushing models. The MotionView generates a General Bushing System file, .gbs file, which defines the bushing properties.
You can add an Altair Bushing Model, also known as AutoBushFD, a frequency-dependent bushing, to your MotionView model using the Add Auto Entity tool in MotionView.
The friction torque resists rotation of the bodies relative to one another. The friction model supports stiction and
sliding effects as well as a measured friction torque due to preload in the bushing.
Use Mount Stiffness when you want to approximate the structural deflection of the bodies that the bushing connects
due to the load that the bushing carries. Mount stiffness is modeled as a set of linear springs and dampers in series
with the bushing stiffness and damping, thus softening the connection between the bodies. Alternatively, you can use
flexible bodies to model the bodies the bushing connects.
You can activate Mount Limits to simulate material contact between the bodies that the bushing connects. This contact
limits the bushing deflection. When the deflection is sufficient in a given direction to close the gap distance, the
mount limit forces or torques become active. The forces and torque are computed using an impact function. An exponent
greater than one (1) provides increasing stiffness with penetration. The damping force is smoothed with a cubic step
function over the penetration distance.
In addition to adding a single bushing to your project, you can also add a pair of bushings such as AutoBushFD pair.
When you add a pair, MotionView automatically reflects modifications you make on the left bushing of the pair to the right bushing, unless you choose
otherwise. MotionView assumes bilateral symmetry about the global X-Z plane.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability,
scalability, and robustness, and to gain more confidence in HyperWorks products.
Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed
files, or remove all the files that resides in the installation directory.
The Preload/Offset/Scale tab displays the force characteristics of your bushing as
you see in the following figure:
Select the Preload/Offset/Scale tab.
Note: The Preload default value = 0; The Offset default value = 0; and the Scale
default value = 1.0. The same holds true for both translational and
rotational directions.
Enter the Preload Force X, Y and Z values as a real
value. Positive preload (Pk) values act to attract the two
bodies.
Enter the Preload Torque X, Y and Z values as a real
value. Positive preload torque values act clockwise about the given axis (that
is, x, y or z) on body 1 and counter-clockwise on body 2.
Enter the Offsets Disp X, Y and Z values as a real
value. Displacement offsets (Qk) are subtracted from the actual
displacement of body 1 with respect to body 2.
Enter the Offsets Angle X, Y and Z values as a real
value. Angle offsets are subtracted from the actual angular displacement.
Enter the Scales Disp X, Y and Z values as a positive,
real value. The displacement scale (Hk) scales both the input
displacement and velocity, but not the displacement offset. The default value is
one (1).
Enter the Scales Angle X, Y an Z values as a positive,
one (1).
Enter the Scales Force X, Y and Z values and
Torque X, Y Z value as positive, real values. Enter a
positive, real value. The force scale (Vk) scales the force function,
but not the preload. The default value is one (1).
The following figure shows the effect of preload and offset on a bushing:
The bushing force for the Kth direction (x, y, z, ax, ay, az) is
defined by a function:(1)
Fk=−Gk(qk,˙qk,xk,t)
Where,
Fk
Force in the kth direction
Gk(dk,˙dk,xk,t)
Force function in the kth direction
dk
Displacement input in the kth direction
˙dk
Velocity input in the kth direction
xk
Array of internal state (that is, hysteresis) in the kth
direction
t
Time
The displacement offset Qk and the displacement scale
Hk modify the displacement and velocity to compute new inputs to
function G as follows:
qk=Hk⋅dk−Qk is the scaled, offset displacement.
˙qk=Hk⋅dk is the scaled velocity.
So force is then
computed using the modified inputs qk and ˙qk:(2)
Fk=−Gk(qk,˙qk,xk,t)
Finally, the force/torque preload Pk and
force/torque scale Vk modify the output so the force computation
is:(3)
