Manufacturing Solutions
Visualizing Moldflow Results
Moldflow now (since MPI 6.1) has an option to export H3D file that can be post-processed with HyperView. If you have a older version of Moldflow MPI, then you can use the API interface with patout.vbs (comes with MPI installation) and export results in Patran neutral format.  HyperView supports the Patran neutral format for post-processing Moldflow results.
For more information, refer to HyperView Moldflow Results Reader in the HyperView online help.
See Also:
Moldflow Utility Menu
