Manufacturing Solutions
Utility Menu
Utility Menu
Utility Menu
The Metal Rolling Utility menu lists options for selecting and assigning material properties, defining and applying boundary conditions, defining process conditions, and exporting data files to HyperXtrude. The buttons in the Utility menu provide shortcuts to native HyperMesh panels and access to pop-up menus and other macro panels. These macros are organized in logical process flow.
The following options are available on the main page of the Utility menu for Metal Rolling Analysis:
utility_menu_mr
Utils
Clear Temp Nodes
Deletes temporary nodes from the model.
Tools
Split Tets
For the selected components having TET4 elements are converted to HEX8 element config.
Select Units
Opens the unit selection window, where you can select the unit system, which automatically updates the other units. In case of Mixed, you can choose appropriate length, temperature, velocity and stress units.
Material Database
Opens the materials database, from which you can select materials, assign material properties to components, and view viscosity/flow stress graphs.
Boundary Conditions
Create/Edit BC
Allows you to define and assign boundary conditions on element faces.
Check Undefined BC
Identify the external faces without loads.
Check Duplicate BC
Identify duplicate loads in the model.
Process Data
Displays a menu that allows you to specify run control parameters.
Extract Points
Allows you to define solution monitoring points in the mesh. The HyperXtrude solver prints detailed solution history at these monitoring points.
Model Summary
Displays the summary of process conditions, materials assigned, BCs created, and element statistics of the model.
Export Data
Export/Launch Solver
Generates Data Deck for solver in interactive and batch mode. Starts the HyperXtrude solver using the current model, existing data deck, or a restart file.
See Also:
Extrusion Wizard
HyperXtrude Users Guide
Importing HyperXtrude Data Decks
Exporting HyperXtrude Data Files
