Manufacturing Solutions
Defining Process Parameters
Previous topic Next topic Expand/collapse all hidden text
Once the boundary conditions have been set up and assigned, the process parameters should be defined. The process parameters allow you to control the run by specifying the equations/physics to be solved and defining control parameters such as convergence tolerances and the number of iterations/time steps.
Click Parameters on the Metal Rolling Utility menu. The Define Altair HyperXtrude Analysis Parameters dialog contains the following tabs:
hmtoggle_plus1greySession Tab
General Analysis Data
process_param_mr_01
hmtoggle_plus1greyMetal Rolling Tab
Process Specific Data
process_param_mr_02
hmtoggle_plus1greyAdvanced Tab
Advanced Parameters
You probably will not modify these parameters often.
process_param_mr_03
hmtoggle_plus1greyUser Defined Commands Tab
This panel is used to specify special commands to control the job. This is an advanced feature.
process_param_mr_04
