Manufacturing Solutions
Uses of the HX-Forge User Profile
The HX-Forge user profile is used for:
•Creating HX-Forge data decks
•Launching HX-Forge solver using the current model and existing data deck
The HX-Forge interface in HyperMesh provides the tools to create HX-Forge data.  This data is organized into the following two files:
•*.grf files containing the mesh, material data, boundary conditions, sequence of forging steps, tool set information and other special problem data
•*.frg files containing commands to set process parameters and control the solver operations.  Some of these commands are in Tcl language.
In order to make the process of generating data files simple and efficient, the following features are embedded in the interface.
•Easy-to-use, GUI-driven interface
•Material database
•Process parameters
•Model summary
•Data import and export
