Manufacturing Solutions
HX-Forge Utility Menu
The HX-Forge Utility menu lists options for importing a model into HyperMesh, selecting and assigning material properties, defining and applying boundary conditions, defining process conditions, and exporting data files to be used with HX-Forge solver. The buttons in the Utility menu provide shortcuts to native HyperMesh panels and access to pop-up menus and other macro panels. These macros are organized in a logical process flow.
The following options are available on the main page of the HX-Forge Utility menu for Forging Analysis.
Data files for HX-Forge can be created either with the use of the Forging Wizard or by manually following a sequence of steps.
hx_forging_utility_menu
Utils
Clear Temp Nodes
Clear all the temporary nodes, if any, in the model
Model Setup Tools
Forging Wizard
A process of setting up the model files for HX-Forge solver
Select Units
Choose the units used in modeling the problem
Material Data
Select materials from a material database and assign material properties to components. View viscosity/flow stress graphs for materials.
Boundary Conditions
Inspect/Setup BCs
View and assign boundary conditions on element faces
Check Undefined BC
Identify external faces without loads
Check Duplicate BC
Identify duplicate loads
Process Data
Create/Edit Tool Set
To create and edit tool set information
Setup Process Builder
Specify forging sequence and information for all the forging stages
Specify process control parameters
Extract Points
Define solution-monitoring points
Model Summary
Inspect summary data such as number of elements and loads
Export Data
Export/Launch Solver
Start the HX-Forge solver using the current model, an existing data deck, or a restart file.
