Manufacturing Solutions
Typographical Conventions
The typographical conventions used in the HyperXtrude online Help are:
Panels and menu items are bold, italicized.
File names and program code are in Courier.
All key words are case sensitive and must be entered as presented.
Braces, { }, are part of the syntax and must be included in data files.
The data within box brackets, [ ], is optional.
All comment cards must start with #.
All input values are specified in a free format with successive variables separated by commas or blank spaces.
All valid options for key words are listed in parenthesis and are separated by a vertical line, |. Only one of these must be used to input data.
Default values are listed within angle brackets, < >.
See also
HyperXtrude Files
