Manufacturing Solutions
HyperXtrude Output Files
HyperXtrude creates the following files during the analysis and post-processing.
File name
File type
Jobname_000.out
Standard output with convergence history. This is the key output file you should inspect to understand the run and its diagnostics.
ASCII
#autosave.phx
HyperXtrude save file with results from previous nonlinear iteration. This file can be used to restart the analysis, especially when the run ends/crashes for some reason.  This file will be automatically deleted unless the pset parameter SavePHXfileYesNo is set to yes.
Binary
Jobname.save.phx
HyperXtrude results file created once the solution is converged. This file also contains solutions from mesh refinement steps and time steps.  This file will be automatically deleted unless the pset parameter SavePHXfileYesNo is set to yes.
Binary
Jobname.mod
Finite element mesh that can be imported into HyperMesh. This is not often used. To enable this output, add these commands to the TCL file:
pset Trans ResultsFileType res
set env (SAVE_HMFILE) ON
ASCII
Jobname.res
Results file that can be imported into HyperMesh. This is not often used. To enable this output, add these commands to the TCL file:
Binary
Jobname.h3d
Results file in HyperView format. This is the main output file for post-processing the results.
Binary
Jobname.pth
Solution along a particle path line.
ASCII
Jobname.fem
OptiStruct input deck for tool deflection and fatigue analysis
ASCII
Jobname.rtm
This file will be written for metal extrusion analysis and it contains information needed by the automatic report generator
ASCII
Jobname.srf
Boundary fluxes and forces
ASCII
See also
HyperXtrude Files
