To turn off the display of IDs of specified data types |
1. | Click the switch and select the data type of the entities whose IDs you want to remove. |
2. | Indicate the entities where you want to remove the IDs by picking them on your model, or click the data type and choose from the extended entity selection menu or list provided. |
3. | Click off. |
The entities' IDs are removed from the numbers mark.
