Manufacturing Solutions
To spin elements
To spin elements
To spin elements
1.Select the spin elems subpanel.
2.Indicate the elements you want to spin:
Pick the elements on your model
or
Click elems and choose from the extended entity selection menu.
HM_Panels_bmp00309
3.Use the plane and vector collector to specify a plane.
The elements are spun about the normal of the plane.
4.Click base and select a base point.
HM_Panels_bmp00310
5.Click angle = and specify an angle through which to spin the elements.
6.Click on spin = and enter the number of elements you want to generate along the path of the spin.
7.Click spin+.
To generate the elements in the opposite direction, click spin-.
HM_Panels_bmp00311
