Manufacturing Solutions
To spin a line to create a surface
1.Select the spin geoms subpanel.
2.Click the entity selector switch and select lines.
3.Select the line(s) you want to spin.
HM_Panels_bmp00306
4.Use the plane and vector collector to specify a plane.
The selected line(s) are spun about the normal of the plane.
5.Click base and select a base point.
HM_Panels_bmp00307
6.Select angle = and specify an angle through which to spin the line.
7.Click the lower right switch and select the desired mesh and surface options.
For information regarding the meshing options, refer to the Automeshing section of the User’s Manual.
8.Click spin+.
To build the surface in the opposite direction, click spin-.
HM_Panels_bmp00308
