Manufacturing Solutions
To create surfaces by spinning lines
1.Select the Surfaces panel, spin subpanel.
2.Set the collector to lines and select the relevant lines.
3.Optionally, check on or off the merge input lines checkbox.
4.Specify how the new surfaces will be organized by setting the create in option.
5.Define the axis of rotation using the plane/vector collector.
6.Enter the start angle value.
7.Enter the end angle value.
8.Click spin + or spin -.
9.To undo, immediately click reject.
