Manufacturing Solutions
To create surfaces by spinning nodes
1.Select the Surfaces panel, spin subpanel.
2.Set the collector to node list and select the nodes in the proper order.
3.Define the axis of rotation using the plane/vector collector.
4.Enter the start angle value.
5.Enter the end angle value.
6.Click spin + or spin -.
7.To undo, immediately click reject.
