Manufacturing Solutions
To build a surface between a row of nodes and a line
1.Click the upper entity selector and select nodes.
2.Pick the row of nodes where you want to create a surface.
HM_Panels_bmp00264
3.Click the lower entity selector and select lines.
4.Pick the line where you want to create a surface.
HM_Panels_bmp00265
5.Click the rightmost switch and select the desired mesh and surface option.
For information regarding the meshing options, refer to the Automeshing section in the User’s Manual.
6.Select auto reverse if you want to use the auto reverse feature.  (See Comments.)
7.Click create.
HM_Panels_bmp00266
