Manufacturing Solutions
To build a surface between two rows of nodes
1.Click the upper left switch and select nodes.
2.Select the first row of nodes where you want to create a surface.
HM_Panels_bmp00261
3.Click the lower left switch and select nodes.
4.Select the second row of nodes where you want to create a surface.
HM_Panels_bmp00262
5.Click the rightmost switch and select the desired mesh and surface option.
For information regarding the meshing options, refer to the Automeshing section in the User’s Manual.
6.Select auto reverse if you want to use the auto reverse feature.  (See Comments.)
7.Click create.
HM_Panels_bmp00263
