Manufacturing Solutions
The Command File (*.tcl)
Reference Quantities, job execution, and control commands are entered in the *.tcl file. Data/commands entered in this file allow you to select and load the gridfile and assign run control data and fluid properties. Advanced options enable you to post-process results in a batch mode. Basic commands are grouped into two categories, those used to initialize/assign values to variables, and job execution statements. Initialization statements begin with the command pset. Job execution statements are different for each task.
See also
Commands
Algorithm Parameters
Process Parameters
Error Estimation and Adaptation Parameters
