Manufacturing Solutions
Status Bar
Status Bar
Status Bar
The status bar is located at the lower left corner of the window, below the panel area.  It displays information pertaining to the currently loaded model as well as descriptions of the pages and panels.  When you are on one of the main menu pages (not within a panel), the current include, component, and load collector display, along with the current menu page name (i.e., Geometry) display.
You can quickly change the active collector by clicking the displayed include, component, and load collector.  Simply clicking in the corresponding box on the message bar accesses the appropriate panel which lists the available collectors.
The status bar also displays a brief description of the panel when you hold down the left mouse button on the panel button (see below).
message_bar
When you are in a panel, the status bar displays the current panel title and model status.  Panel titles display on the left side of the bar.  If you access a panel by using a function key, the bar displays the current panel name on the left (in black) and the original panel name to the right (in gray).  The current component and load collector names are displayed on the right side of the bar.
message_bar_02
Messages also appear on the message bar and temporarily override the title and status information.
Messages posted on the status bar are color-coded:
red
Error messages.
message_bar_03
green/gray
Miscellaneous messages, such as status updates or completed operations.  You can also obtain a brief description of a panel’s function if you hold down the left mouse button over a panel button.  These messages appear in green when using HyperMesh classic dark menu colors and they appear in gray when using Windows light menu colors
Click a mouse button to remove a message from the status bar.
See also
Graphics Area
User Interface
