Manufacturing Solutions
Start From Existing Mesh
This feature is available in Plate Meshing, Coextrusion Analysis and Melt Flow Analysis wizard. For enabling this feature, select Yes for the question “Have existing mesh in your model?” in the Analysis Data page under Set Analysis Requirements.
mfa_11
The material update page lists all the components that has solid mesh. Select and assign the material.
mfa_06
In Inlet/Outlet selection page, pick one element on each face for both Inlet and Outlet.
mfa_12
