Manufacturing Solutions
Create Symmetry BCs
Create Symmetry BCs
Create Symmetry BCs
This feature is available in Plate Meshing, Coextrusion Analysis and Melt Flow Analysis wizard. For enabling this feature, select Yes for the question “Do you have SYMMETRY in your model?” in the Process Data page under Set Analysis Requirements.
mfa_13
In Inlet/Outlet selection page, pick symmetry surfaces or one element on each symmetry face.
mfa_14
