Manufacturing Solutions
Standard Views Toolbar
The Standard Views toolbar contains functionality for quickly changing the view of the model in the graphics area to a standard view including fitting the model in the graphics area.
standard_views_toolbar
The Standard Views toolbar can be turned on and off from View > Toolbars sub-menu.  The detailed behavior of each tool button is described in the table below.
Icon
LEFT Click / Behavior
RIGHT Click / Behavior
viewPrevious-24
Previous View
Left click tool button to return to the previous view.
Same
viewFit-24
Fit Model
Left click tool button to fit the currently displayed model in the graphics area.
Same
viewRefresh-24
Refresh Graphics Area
Left click tool button to refresh the graphics area
Same
viewAxisOrientationYXTop-24
xy Top Plane View
Left click tool button to put the currently displayed model into the xy top plane view
Same
viewAxisOrientationYXBottom-24
xy Bottom Plane View
Left click tool button to put the currently displayed model into the xy bottom plane view
Same
viewAxisOrientationZXLeft-24
xz Left Plane View
Left click tool button to put the currently displayed model into the xz left plane view
Same
viewAxisOrientationZXRight-24
xz Right Plane View
Left click tool button to put the currently displayed model into the xz right plane view
Same
viewAxisOrientationZYRear-24
yz Rear Plane View
Left click tool button to put the currently displayed model into the yz rear plane view
Same
viewAxisOrientationZYFront-24
yz Front Plane View
Left click tool button to put the currently displayed model into the yz front plane view
Same
viewAxisOrientationIso-24
Isometric View
Left click tool button to put the currently displayed model into an isometric view
Same
viewReverseVertical-24
Reverse View
Left click tool button to reverse the model view about an “imaginary” vertical axis in the middle of the graphics area.
Same
viewUser-24
User Views Dialog
Left click tool button to open up the User Views dialog.  This dialog allows for user defined views to be saved and restored.
True View panel
Left click tool button to open True View panel.
