Manufacturing Solutions
Shortcut Mapping Examples
To create a shortcut key "e" that deletes all the elements in the model, enter the following commands in the command field next to the key "E":
*createmark elements 1 "all"; *deletemark elements 1;
To create a shortcut key "L" that accesses the lines panel, enter the following in the command field next to the key "L":
 hm_pushpanel ;
To create a shortcut key "J" that runs a macro to find all the elements with jacobian < 0.7:  this macro already exists in the QA page of the Utility menu. To call the same macro, enter the following in the command field next to the key "J":
 *evaltclstring "macroElementJacobian 0.7" 0
To create a shortcut key <shift + K> that runs a macro to check whether any beam/bar elements exist in the model and display them only:
1.Create a findbeams.tcl file with following commands:
Proc displayonlybeams {}
 *createmark elements 2 "by config" 60 63
       set beams [hm_getmark elements 2]
 *clearmark elements 2
 if { ![Null beams]}
         *displaycollectorwithfilter comps "none" "" 1 1;
         eval *createmark elements 1 $beams;
         *findmark elements 1 0 1 elements 0 2;
 } else {
               hm_usermessage "No beam elements in this model"
2.In the Key-Command Mappings window, select shift from the Shortcut Key pull down menu.
3.Enter the following in the command field next to the key <K>.
*evaltclstring displayonlybeams
4.In the file field, click the "…" button to browse to and select the findbeams.tcl file.
See also
Mapping Keyboard Shortcuts
Input Controls
