Manufacturing Solutions
Input Controls
Input Controls
Input Controls
The menu items on each panel indicate the information that is needed to correctly perform the panel’s function.  Each panel contains input collectors, plane collectors, data entry fields, and function buttons.  Most panels also have toggles and switches that allow you to alternate between choices or select options from a list.
For details on each of these input controls, consult the following topics:
Using the Mouse
Using the Keyboard
Input collectors
Menu Buttons
Pull down Selections
Pop-ups
Toggles
Plane and Vector Selector
Input Fields
Color Palette
