Manufacturing Solutions
Session Parameters
Session Parameters
Session Parameters
Parameter
Default
Valid Options
Significance
Jobname
None
String
All the file names created use this name as a prefix. Job name should contain only alphanumeric characters and underscore.
Title
None
String
Title string will appear on the postprocessor GUI.
MaximumVelocity
1
positive value
If -1 is specified, it will act like a flag
If set to -1 it turns off Maximum Velocity clipping. Otherwise, the velocity is clipped if the value is greater than the specified Maximum Velocity. This is useful to compensate for the inertial effects.
UpwindFactorForSaturation
1
0 - 2
Control the level of upwinding used. Increasing the upwinding factor increases the smearing.
UpwindFactorForTemperature
1
0 - 2
DiagnosticsLevel
0
0 - 4
Increasing the number increases the detail of diagnostic messages.
TimerVerbosity
1
0 - 4
Increasing the number increases the CPU time diagnostics.
