Manufacturing Solutions
Time and Nonlinear Loop Control Parameters
Parameter
Default
Valid Options
Significance
MaxNonlinearIters
25
>1
Number of nonlinear iterations in a time step. Ideally, this should be between 3 and 5.
NonlinIterTolerance
0.001
>0.00
Tolerance of nonlinear iterations. Default value is preferred.
NumTimeSteps
1
>1
Number of time steps, this should be based on the time it will take to fill the model.
Deltat
1
>0.00
Time step size in seconds
AutoSaveFrequency
1
>0
Frequency at which the solution will be saved
