Manufacturing Solutions
On/Off Switches
On/Off Switches
On/Off Switches
Parameter
Default
Valid Options
Significance
SupgOnOff
On
On/Off
SUPG  denotes Streamwise Upwinding Petrov Galerkin method. It is important to have this parameter on. You can control it using the variable UpwindFactorForSaturation.
CapillaryOnOff
Off
On/Off
Capillary forces arise due to the interaction of two different fluid resin and air. This variable enable the inclusion of capillary pressure in the model equation.
BouyancyOnOff
Off
On/Off
Bouyancy forces come into play due to gravity. This may be significant in some RTM fills. When on, this  enables the inclusion of gravity terms in the model equation.
HeatTransferOnOff
Off
On/Off
Includes heat transfer in the analysis. In a realistic problem, this should be on.
CureOnOff
Off
On/Off
Curing kinetics of the resin is included in the analysis if the variable is turned on.
Fluid_type
0
1/0
1 indicates that VARTM is on and compressibility of air comes into play.
0 turns off the compressibility.
ShockCapturingOnOff
Off
On/Off
Includes terms to capture a sharp front. This option has to be tested and improved. Please leave it off.
ClipSaturationOnOff
Off
On/Off
Enforces digital variation of S distribution thereby reducing smearing. However, this is an artificial approach.
