Manufacturing Solutions
Available Commands
Available Commands
Available Commands
The following TCL commands are available:
Load
The Load command is used to read the data from either the grid file or an existing RTM save file.
The GRF file is loaded to start a new run.
load gridfile_name phlex "Two Phase Flow"
To restart a run from the binary/ASCII save file:
load savefile restart step_number
Source
The source command is used to read in another TCL file. These additional TCL files are usually used to define a user proc function.
source tclfile_name
pset
The pset command is used to initialize variables such as job control parameters or fluid properties.
pset     variable_name     value
A variable can be re-initialized many times.  For example, you can run the job with a constant time step value for a few time steps, and then change the time step before continuing the analysis.
solve
The solve command is used to solve the problem after reading the data and initializing the variables.
solve "solver"
Valid entries for solver are: GMRES and Sparse. GMRES is an iterative solver. It will soon be replaced by PETSc. Sparse is a direct solver and it is the preferred solver and the default. When invoking the solve command for the first time, you have the option to initialize the flow field. This can be done by adding extra options to the solve command. The following table gives the syntax for each option.
interactive
The interactive command is invoked to display the GUI for either post-processing or running the job interactively.
estimate
The estimate command is used to compute the solution error estimates. Before issuing this command, ensure that the error estimation and mesh adaptation parameter are set properly.
refine
The refine command is used to refine the mesh.  The mesh refinement can be isotropic or directional over the entire domain or portions of the flow domain.
refine domain direction
Valid entries for domain are: all | set name
Valid entries for direction are: iso | xi | eta | zeta | normal
Normal indicates that the refinement is normal to a boundary and will work only if the set is a set of elements on a given boundary
You can refine using global XYZ directions instead of xi/eta/zeta
enrich
The enrich command is used to enrich the polynomial order of the elements in the mesh.  Mesh enrichment can be isotropic or directional over the entire domain or portions of the flow domain.
enrich domain direction order
Valid entries for domain are: all (for entire mesh) | set set_name (name of the set eg: billet)
Valid entries for direction are: iso (isotropic refinement) | xi | eta | zeta | normal
Order denotes the new polynomial order (P) of the elements.  The value of P must be less than 4.
adapt
The adapt command is used to automatically refine/enrich mesh. The solution error estimates must be computed and the adaptation parameters set properly before issuing this command.
save
The save command is used to save the solution into a file.
save  save_file_name binary
save  save_file_name ascii
exit
The exit command must be invoked to exit the job after completing the analysis.
