Manufacturing Solutions
Select Model Units
Select Model Units
Select Model Units
The first task in the Runner Balancing Analysis process is Select Model Units. After clicking on the checkbox, the Select Model Units tab is opened, as shown below.
runner_balancing_03
The default unit system is Metric. You can choose from Metric, British and Mixed. For Mixed unit system, you can choose all the units independently. Click OK to set the units. Click Cancel to close the tab
