Manufacturing Solutions
Select Material Data
The second task in the Runner Balancing Analysis process is Select Material Data. The Select and Assign Material from Database dialog appears as shown below.
runner_balancing_04
Click Add to add the materials from the database. Click Close to finish the selection and to close the dialog. The selected polymer material will be assigned to the components that will have the solid mesh of the runner.
