Manufacturing Solutions
Select Material Data
The second checkbox under Set Process Data in the Melt Flow Analysis Wizard tree is Select Material. Select and add polymer materials. If the model has insert, select tool materials also. Clicking Close assigns the selected material.
coextrusion_04
