Manufacturing Solutions
Report Generator
Report Generator
Previous topic Next topic Expand/collapse all hidden text
Report Generator
The Report Generator is a tool that lets you easily post process and publish the results of incremental forming simulations. During a HyperForm session, you can run an analysis on a model and then use the Report Generator to launch HyperView and post process the simulation results.
hmtoggle_plus1greyRADIOSS Incremental
1.Select Tools > Report Generator, and a dialog opens with the following options:
report_generator
2.For Result File, select the A00 file for your current model.
3.For Blank Component, select a component, and then the Result Types that you want to study for the component.  The result types include:
Deformation
Provides the deformation of the sheet at various stages of the forming process.
% Thinning
Creates a thinning distribution contour at the end of the forming process.
Plastic Strain
Creates a plastic strain distribution contour at the end of the forming process.
FLD
Creates a Forming Limit Diagram with a zone contour plot of the points in the FLD.
4.For Export Modes select one of the following:
HTML
Creates an HTML report with the results you specify.
Open Results
Launches HyperView in a separate window and displays the results you specify at the end of the forming stage.
5.If you choose the HTML option, select a file format for exporting images and video into your report: H3D, JPEG or AVI.
6.Click Generate. Based on the Export Mode you specified, the results open in an HTML report or HyperView window.
hmtoggle_plus1greyRADIOSS One Step
report_generator_one_step
2.For Result File, select the model file for your current model.
3.For Result Types, select the results that you want to study for your model.  The result types include:
Initial Blank Shape
Generates the initial blank shape for a part.
% Thinning
Creates a thinning distribution contour for a part.
Plastic Strain
Creates a plastic strain distribution contour for a part.
Formability
4.For Export Modes select from the following:
HTML
or
Open Results
6.Click Generate. Based on the Export Mode, the results open in an HTML report or HyperView window.
