Manufacturing Solutions
Multistage Run in Batch Mode
Multistage process setup in HyperForm can also be run in batch mode. The procedure is as follows:
1.Open the command window.
2.Change the current directory to the folder where the multistage process has been saved.
3.Call the HyperMesh in batch mode hmbatch.exe with –tcl option pointing to batch_msm.tbc file in the following location of the installation
\hm\scripts\hyperform\userprocess
