Manufacturing Solutions
Process Parameters
Process Parameters
Process Parameters
Once the boundary conditions have been set up and assigned, the process parameters should be defined. The process parameters allow you to control the run by specifying the equations/physics to be solved and defining control parameters such as convergence tolerances and the number of iterations/time steps. The Define Altair HyperXtrude Analysis Parameters dialog contains the following tabs:
Session
Process
Advanced
See Also:
Defining Process Parameters
