Manufacturing Solutions
Defining Process Parameters
Previous topic Next topic Expand/collapse all hidden text
Once the boundary conditions have been set up and assigned, the process parameters should be defined. The process parameters allow you to control the run by specifying the equations/physics to be solved and defining control parameters such as convergence tolerances and the number of iterations/time steps.
Click Parameters on the Metal Rolling Utility menu. The Define Altair HyperXtrude Analysis Parameters dialog contains the following tabs:
hmtoggle_plus1greySession Tab
General Analysis Data
analysis_parameters_session
hmtoggle_plus1greyMetal Extrusion Tab
Process Specific Data
This will change for each process.
analysis_parameters
hmtoggle_plus1greyAdvanced Tab
Advanced Parameters
You probably will not modify these parameters often.
analysis_parameters_advanced
hmtoggle_plus1greyUser Defined Commands Tab
This panel is used to specify special commands to control the job. This is an advanced feature.
analysis_parameters_user
hmtoggle_plus1greyTransient Data Tab
To Specify Variable Time Step Command
This panel is used to specify control time step for a transient problem. This allows you to define up to five levels. End time of the last level depends on the extrusion time. Therefore, before specifying time steps, you have to compute extrusion time. The variable time data is updated automatically, if all the data related is valid. It will inform if there are any invalid data. Clicking Default will compute the data automatically and populates the same. This operation is valid only for the Metal Extrusion user profile.
transient_data_tab_equation
In the following image, there are two levels.
In level 1, for 0-5sec -with 5 steps, step size is 1sec..
In level 2, for time 5– 124 sec, with 15 steps, step size is 7.93.
analysis_parameters_transient
See Also:
Process Parameters
HyperXtrude User Profile
