Manufacturing Solutions
Load
Load
Load
The load command is used to read the data from either the grid file or an existing HyperXtrude save file:
load filename filetype {problem type}
Fresh start
Restarted run
filename
grid file name
save file name
filetype
phlex
restart
Problem Type can be either one of the following: Metal Extrusion, Metal Rolling, or Polymer Processing.
