Manufacturing Solutions
intersect subpanel (Nodes panel)
This subpanel creates nodes at the intersection of geometric entities: lines/lines, lines/surfaces, lines/solids, lines/planes, vector/lines, vector/surfaces, vector/solids and vector/plane.
nodespanel_intersect_example
A node is created at each intersection location.
For surface, solid, and plane intersections, if the input line or vector lies on the surface/solid/plane the result is undefined and unpredictable.
For vectors, the magnitude and direction of the vector do not have any effect on the result.  The vector extends through the entire model space.
