Manufacturing Solutions
interpolate on surface subpanel (Nodes panel)
This subpanel creates evenly spaced or biased nodes by interpolating between existing nodes on a surface.
The input nodes are specified as a node list, with each node considered as a pair with the next node in the list.  The nodes are created on the input surface between each node pair.
nodespanel_interpolateonsurface_example
The highlighted opposing corner nodes have 7 interpolated nodes created between them, using Bellcurve biasing.
The nodes are not required to lie on the selected surface, as all input nodes are first projected onto the surface.
