Manufacturing Solutions
interpolate on line subpanel (Nodes panel)
This subpanel creates evenly spaced or biased nodes by interpolating between existing nodes on a line.
The input nodes are specified as a node list, with each node considered as a pair with the next node in the list.  The nodes are created on the input line between each node pair.
The input nodes are not required to lie on the selected line, as all input nodes are first projected onto the line.
nodespanel_interpolateonline_example
5 nodes created between 2 input nodes along a curved line, using linear biasing.
