Manufacturing Solutions
interpolate nodes subpanel (Nodes panel)
This subpanel creates evenly spaced or biased nodes by interpolating between existing nodes in space.
The input nodes are specified as a node list, with each node considered as a pair with the next node in the list.  The specified number of nodes are created on a straight line between each node pair.
The example below shows the effect of adding 5 nodes between the end nodes of a line using different types of bias, with bias intensity 5.0:
nodespanel_interpolatenodes_example
Note:Nodes are created in 3D space, and not merely on geometry:
nodespanel_interpolatenodes_example2
To interpolate nodes along a curved line like the one shown above, use the interpolate on line subpanel instead.
