Manufacturing Solutions
HyperForm Settings
HyperForm Settings
HyperForm Settings
HyperForm Settings are organized into two groups of options known as global settings and process defaults. These options are specific to each user profile.
To access HyperForm Settings, select Preferences > HyperForm Settings. A dialog appears with the options set for the current user profile. The following image shows the dialog for the RADIOSS user profile:
hf_settings
The HyperForm Settings dialog contains the following options:
File Menu
Left-click File and a menu opens with the following options:
Option
Open
Opens an existing processdefaults.dat or settings.dat file.
Save
Saves the current settings as a processdefaults.dat or settings.dat file in the My Documents folder.
Save As...
Saves the current settings as a processdefaults.dat or settings.dat file in the folder you select.
Save In Home
Saves the current settings as a processdefaults.dat or settings.dat file in the HyperForm home directory.
Solvers
The HyperForm Settins dialog includes a Solver dropdown menu from which you can select one the following solvers:
LS-DYNA
RADIOSS
RADIOSS One Step
Die Module
Settings and ProcessDefaults Tabs
The options on the Settings tab and ProcessDefaults tab are specific to each user profile.  Click the following links to view the options for each profile:
LS-DYNA Incremental
RADIOSS One Step
Die Module
RADIOSS Incremental
General Options
These are general options available for each user profile:
Option
Default
Restores a current setting to its default value.
Apply
Applies setting changes to the current session, but does not save the settings.
Close
Closes the dialog.
