Manufacturing Solutions
Die Module
Die Module
Die Module
Settings Tab
The following Settings options are available for the Die Module user profile:
Settings Option
UndercutTolerance
Specifies the tolerance in angle (radians) to determine undercuts in the part.
ProcessDefault Tab
The following ProcessDefaults options are available for the Die Module user profile:
ProcessDefaults Option
ToolOffsetFactor
Offsets tools from the punch or die by value of thickness tool offset factor. You use this option primarily with the Tool build panel and in the Die Process.
BinderDepth
Determines the position of the binder in the stamping direction relative to the part. This is the minimum distance between a part and binder surface. You use this option primarily for binder creation.
BinderOffset
Determines the size of the binder relative to the part. You use this option primarily for binder creation.
FlangeMinWidth
Automatically detects the flanges in the part geometry based on the minimum flange width defined.
FlangeMaxWidth
Automatically detects the flanges in the part geometry based on the maximum flange width defined.
DetectFlangeRadius
Select Yes or No to automatically select the radius along with the flanges. Default is Yes.
