Manufacturing Solutions
LS-DYNA Incremental
LS-DYNA Incremental
LS-DYNA Incremental
HyperForm Settings for the LS-DYNA Incremental user profile include the following:
Settings Tab
See RADIOSS Incremental. The options on this tab are the same for the LS-DYNA and RADIOSS Incremental user profiles.
ProcessDefault Tab
The settings for the LS-DYNA user profile include the following in addition to the options for RADIOSS Incremental.
ProcessDefault Option
d3plotCount
This option is the same as Animation count. Refer to RADIOSS Incremental.
GravityOption
Specifies the option as Implict or Explicit. Default: Implicit.
ElementFormulation
Specifies the element formulation for blank shell elements. Values are 2 and 16. Default value: 2.
StopperMaxVel
Specifies the maximum velocity for stopper. Default value: 0.
StopperMaxVelFactor
Specifies the velocity factor for stopper. Default value: 1.2
LsdynaMemory
Sets the memory in MB for the LS-DYNA incremental solver. Default: 0
LSDYNA_ARGUMENTS
Specifies the arguments that are required during the LSDYNA solver run.
