Manufacturing Solutions
HX Job Manager Configuration Settings
Click the Configure menu and select Configuration Settings.
hx_jm_configure_dialog
Field
PuTTY
Select the installation folder, where PuTTY protocol is installed.
For example: C:/Users/Installs/PuTTY
Gzip
Select the installation folder, where gzip is installed.
For example: C:/Users/ Installs/gz
Configure Server
Click the Configure menu and select Add Server.
hx_jm_configure_server
Field
Service Name
Select/specify service name – this name can be any text with no spaces or special characters.
Host Name
Name of the host – when you create PuTTY configuration make sure the saved session has the same name as the host.
Architecture
Specify architecture of machine. Select  an appropriate option from drop down list. This will be used to control the shell scripts on the remote UNIX/Linux box.
Location
Specify whether the host is local/remote
Max Memory (MB)
Specify maximum memory allowed in the remote machine. There are two components to run a large job 1) RAM and 2) scratch file space.
This option only controls the RAM. Your system administrator (with ulimit) controls the limit of your scratch file size. You should have at least 30+ GB of allowed file size.
Protocol
Specify which protocol (RSH/ SSH/ PuTTY) does the host supports. Select an  appropriate option from drop down list. For a secure shell, it is better to use PuTTY instead of SSH.
PBS
Specify whether the machine is using PBS. Select appropriate option from drop down list.
Machine Type
Specify if machine can used for Mesh/Solve/Both (HM/HX/BOTH) or solve in RADIOSS. Please select appropriate option from drop down list.
Version
Specify version of HX/RADIOSS solver installed in machine. Please select appropriate option from drop down list. If you have multiple versions and would like to use all of them, then you should create a separate configuration for each version.
HM Bin Folder
Specify location of HM bin in case of local host.
HX Bin or RADIOSS Bin Folder
Specify solver bin location in case of local host.
PC Working Folder
You can leave this field blank. If you specify , this will be used to map folder structure on remote machine as you have in local PC. For example, if you specify local PC working directory as ‘c:/hx_runs’. In addition, your remote working folder as /users/hx-runs. Now if your current project directory is c:/hx_runs/examples/test_cases/example1/ the HX Job Manager will copy your folder structure from ‘/examples/test_cases/example1’ in the remote working folder on the machine and will launch the run.
Remote Working Folder
Specify remote working folder on host machine. You can leave it blank, if you are configuring for local machine.
HXJM Script Folder
Specify the location of the Unix scripts copied on to remote machine. These scripts can be copied to remote machine using the advanced option which is mentioned in the next section.
