Manufacturing Solutions
Generate Tool Mesh (Starting with Solids and Using Auto Mesh Size Estimation)
In Set Analysis Requirements Page 2, selecting Yes for the question Use Automatic Mesh Size Estimation? will enable the Automatic Mesh Size Estimation dialog.
HX_0101_03a
To generate the tool mesh, click Generate Tool Mesh. It will display all the element sizes for each metal extrusion assembly disabled. This has a slider bar for every component to control the mesh size. As the slider is moved you can see the element sizes.
generate_tool_mesh_02
Click Mesh to generate a tetra mesh for the selected solids.
