Manufacturing Solutions
Generate Tool Mesh (Starting with Solids)
The next checkbox on the Extrusion Wizard tab is Generate Tool Mesh.
If you start with solids, then this macro will be used to generate mesh. It will require you to identify the components in which solids are stored for each assembly.
generate_tool_mesh
Click Remesh to delete the 3D mesh generated and regenerates the 3D components with element sizes specified. Click OK to proceed further.
