Manufacturing Solutions
Generate Workpiece Mesh (Starting with Solids Using Auto Mesh Size Estimation)
In Set Analysis Requirements Page 2, selecting Yes for the question Use Automatic Mesh Size Estimation will enable the Automatic Mesh Size Estimation dialog.
HX_0101_03a
Click Generate Workpiece Mesh to display all the element sizes for each metal extrusion assembly disabled. This has a slider bar for every component to control the mesh size. As the slider is moved you can see the element sizes.
auto_mesh_size_est_02
Click Mesh to generate a tetra mesh for the selected solids.
