Manufacturing Solutions
Generate Workpiece BCs (Set Process Conditions)
The next checkbox on the Extrusion Wizard tab is Set Process Conditions.
This macro is used to create all the BCs and assign process conditions. This automatic generation is a complex step and is not guaranteed to be 100 percent accurate. Hence, you are required to inspect the model before submitting the data for analysis.
set_process_conditions
If a press is selected, clicking OK enables press data checks, which are shown in a separate window.
press_data_checks_02
