Manufacturing Solutions
Create Billet
Create Billet
Create Billet
The Create Billet Wizard is used to automate the creation of Billet.
create_billet
You can pick from the following options which will determine the center of base surface of billet:
Any base surface coincident with billet base surface (including billet surface)
Any circular edge
Enter base center coordinates manually
Based on your selection you will be required to pick either a surface, line or enter center coordinates.
Next, enter the Billet diameter, Container inner diameter and Billet length. Based on conservation of volume, the Adjusted Billet Length will be calculated as per following formula:
Click create and a billet with diameter equal to container inner diameter and length equal to adjusted billet length will be created.
