Manufacturing Solutions
Quick Solid Edit
Quick Solid Edit
Quick Solid Edit
The Quick Solid Edit Wizard lets you
Merge solids
Share surfaces between solids
solid_edit
Select Merge to merge solids, or Share to share surfaces between solids. After making your choice, select the solid on which you want to perform the operation and click proceed.
